Saltar al contenido principal
Samsung HD Pro LED Light Ring Replacement
AllisonBridges
AllisonBridges y 2 otros contribuidores
Última actualización: March 19, 2021
5 - 10 minutos
Fácil
Mejor introducción
Qué necesitas
Herramientas
  1. Samsung HD Pro LED Light Ring Replacement, Casing: paso 1, imagen 1 de 1
    • Locate a small opening around the front panel of the camera.
  2. Samsung HD Pro LED Light Ring Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung HD Pro LED Light Ring Replacement: paso 3, imagen 1 de 1
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung HD Pro LED Light Ring Replacement: paso 4, imagen 1 de 1
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung HD Pro LED Light Ring Replacement: paso 5, imagen 1 de 1
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
  6. Samsung HD Pro LED Light Ring Replacement, LED Light Ring: paso 6, imagen 1 de 1
    • Locate the small circuit board surrounding the lens in the removed front portion of the device.
  7. Samsung HD Pro LED Light Ring Replacement: paso 7, imagen 1 de 1
    • Push the four white tabs away from the center of the lens housing while pulling the led ring up near each tab.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 528
