Saltar al contenido principal
Samsung Galaxy Tab 8.9 Battery Replacement
Dan D
Dan D y 11 otros contribuidores
Última actualización: May 7, 2024
10 - 20 minutos
Moderado
Introducción
Ir al paso 1
As a laptop battery ages, it will gradually lose the ability to hold a charge and die more quickly. This guide will show you how to replace your battery and bring life back to your laptop.
Qué necesitas
Herramientas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Ver más…
  1. Samsung Galaxy Tab 8.9 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Battery Replacement: paso 2, imagen 1 de 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Battery Replacement: paso 3, imagen 1 de 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Battery Replacement: paso 4, imagen 1 de 1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: paso 5, imagen 1 de 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: paso 5, imagen 2 de 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Battery Replacement: paso 6, imagen 1 de 2 Samsung Galaxy Tab 8.9 Battery Replacement: paso 6, imagen 2 de 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Battery Replacement: paso 7, imagen 1 de 3 Samsung Galaxy Tab 8.9 Battery Replacement: paso 7, imagen 2 de 3 Samsung Galaxy Tab 8.9 Battery Replacement: paso 7, imagen 3 de 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: paso 8, imagen 1 de 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: paso 8, imagen 2 de 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: paso 8, imagen 3 de 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Battery Replacement: paso 9, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: paso 10, imagen 1 de 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: paso 10, imagen 2 de 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: paso 10, imagen 3 de 3
    • Use a spudger to lift up and separate the battery from its housing.
Conclusión
4 personas más completaron esta guía.
Dan D
Miembro Desde 09/25/14
160 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 11-4, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
Miembros de 4
10 Guías creadas
Un comentario
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
Paul Jackson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 33
Todo El Tiempo: 4,764
