Saltar al contenido principal
Samsung Galaxy Tab 3 Kids Aux Port Replacement
ajhoffman
ajhoffman y 3 otros contribuidores
Última actualización: September 13, 2021
10 minuto
Moderado
Introducción
Ir al paso 1
If you are experiencing issues with no audio or unclear audio while using the Samsung Galaxy Kids Tab 3 7.0, use this guide to replace the aux port. The aux port allows audio transmission through an auxiliary cord, and may be causing the issue.
Before starting with the replacement guide, remove any dust or debris from the port and try several different auxiliary cords to ensure the root cause of the audio issue is the aux port.
Qué necesitas
Herramientas
  1. Samsung Galaxy Tab 3 Kids Aux Port Replacement, Aux Port: paso 1, imagen 1 de 2 Samsung Galaxy Tab 3 Kids Aux Port Replacement, Aux Port: paso 1, imagen 2 de 2
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 2, imagen 1 de 1
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 3, imagen 1 de 3 Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 3, imagen 2 de 3 Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 3, imagen 3 de 3
    • Lift up the (ZIF) zero insertion force connectors using the plastic opening tool, separating the connectors from the ribbon cables.
  4. Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 4, imagen 1 de 2 Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 4, imagen 2 de 2
    • Remove the ten 4 mm Phillips #000 screws holding the motherboard to the device.
  5. Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 5, imagen 1 de 3 Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 5, imagen 2 de 3 Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 5, imagen 3 de 3
    • Remove the motherboard from the device by carefully lifting it out.
  6. Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 6, imagen 1 de 1
    • Remove the two screws holding down the aux port.
  7. Samsung Galaxy Tab 3 Kids Aux Port Replacement: paso 7, imagen 1 de 1
    • Remove the aux port by gently lifting it out of the device.
Conclusión
2 personas más completaron esta guía.
ajhoffman
Miembro Desde 01/04/14
182 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 2-6, Nance Fall 2016 Miembro de USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 734
