Saltar al contenido principal
Samsung Galaxy S III Motherboard Assembly Replacement
Walter Galan
Walter Galan y 4 otros contribuidores
Última actualización: December 21, 2017
Sin estimación
Moderado
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Introducción
Ir al paso 1
Prereq only.
Qué necesitas
Herramientas
  1. Samsung Galaxy S III Motherboard Assembly Replacement, Motherboard Assembly: paso 1, imagen 1 de 1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  2. Samsung Galaxy S III Motherboard Assembly Replacement: paso 2, imagen 1 de 2 Samsung Galaxy S III Motherboard Assembly Replacement: paso 2, imagen 2 de 2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  3. Samsung Galaxy S III Motherboard Assembly Replacement: paso 3, imagen 1 de 2 Samsung Galaxy S III Motherboard Assembly Replacement: paso 3, imagen 2 de 2
    • Disconnect the display data cable from the motherboard.
  4. Samsung Galaxy S III Motherboard Assembly Replacement: paso 4, imagen 1 de 3 Samsung Galaxy S III Motherboard Assembly Replacement: paso 4, imagen 2 de 3 Samsung Galaxy S III Motherboard Assembly Replacement: paso 4, imagen 3 de 3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  5. Samsung Galaxy S III Motherboard Assembly Replacement: paso 5, imagen 1 de 1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  6. Samsung Galaxy S III Motherboard Assembly Replacement: paso 6, imagen 1 de 2 Samsung Galaxy S III Motherboard Assembly Replacement: paso 6, imagen 2 de 2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 32
Todo El Tiempo: 179
