Saltar al contenido principal
Samsung Galaxy S Blaze SD Card Slot Cover Replacement
Rene Bolanos
Rene Bolanos y 6 otros contribuidores
Última actualización: June 30, 2023
10 - 20 minutos
Fácil
Rebanar y Trocear
Introducción
Ir al paso 1
This guide will show how to properly replace the SD card slot cover on a Samsung Galaxy S Blaze 4G. The replacement of the SD card slot cover is an easy process with no surprises. You will need to be careful while taking out the screws, the screws will damage easily.
Qué necesitas
Herramientas
  1. Samsung Galaxy S Blaze SD Card Slot Cover Replacement, SD Card Slot Cover: paso 1, imagen 1 de 1
    • Make sure the device is powered off and not plugged into a power source.
    • Remove the back plate to reveal the battery.
  2. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 2, imagen 1 de 1
    • Use a spudger or your fingers to remove the battery from the phone.
  3. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 3, imagen 1 de 2 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 3, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws from the device frame.
  4. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 4, imagen 1 de 1
    • Use the blue plastic opening tool to gently pry the frame off the phone.
    • Work around the phone with the blue plastic opening tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 5, imagen 1 de 2 Samsung Galaxy S Blaze SD Card Slot Cover Replacement: paso 5, imagen 2 de 2
    • The SD cover is held in place on the frame by a small tab.
    • Unhook the tab of the SD card slot cover from the frame of the device.
    • This is what the tab of the SD card slot cover looks like.
Conclusión
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
3 personas más completaron esta guía.
Rene Bolanos
Miembro Desde 03/05/15
435 Reputación
2 Guías creadas
Equipo
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 19
Todo El Tiempo: 396
