Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Galaxy Note 10.1 microSD Port Replacement
Qué necesitas
  1. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: paso 1, imagen 1 de 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: paso 1, imagen 2 de 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Top Piece: paso 1, imagen 3 de 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: paso 2, imagen 1 de 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: paso 2, imagen 2 de 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the Back Cover: paso 2, imagen 3 de 3
    • Unscrew the three 5 mm screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: paso 3, imagen 1 de 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: paso 3, imagen 2 de 3 Samsung Galaxy Note 10.1 microSD Port Replacement, Removing the microSD Port: paso 3, imagen 3 de 3
    • Unscrew the two 2 mm screws indicated by the red circles with the #00 Philips Screwdriver.
    • Starting with the black motherboard connector, remove the module indicated by the red box in the second picture.
    • Replace the microSD port with a similar model.
Conclusión
5 personas más completaron esta guía.
Tyler Salomone
Miembro Desde 09/22/14
1,050 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 3-7, Brown Fall 2014 Miembro de USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
Miembros de 3
9 Guías creadas
2Guía Comentarios
Be sure to include screw lengths to the nearest mm on all guides.
Dan Brown - Contestar Compartir
In this guide, you missed a step on removing the battery.
John Peterson - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 35
Todo El Tiempo: 4,184
