Saltar al contenido principal
Replacement the hard disk on Dell XPS 12 9Q23
Schwarzer
Schwarzer y otro contribuidor
Última actualización: March 18, 2024
15 minuto
Moderado
Guía Destacada
Guía aportada por comunidad
Introducción
Ir al paso 1
Do you want to change your hard disk to increase its capacity or replace it, because it no longer works? Perfect, you've come to the right place, this tutorial is for you!
Qué necesitas
  1. Replacement the hard disk on Dell XPS 12 9Q23, Battery: paso 1, imagen 1 de 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Replacement the hard disk on Dell XPS 12 9Q23: paso 2, imagen 1 de 1
    • Carefully remove back panel after all screws have been removed.
  3. Replacement the hard disk on Dell XPS 12 9Q23: paso 3, imagen 1 de 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Replacement the hard disk on Dell XPS 12 9Q23: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Replacement the hard disk on Dell XPS 12 9Q23, Remove the battery: paso 5, imagen 1 de 1
    • Once all the screws have been removed the battery is now safe to extract
  6. Replacement the hard disk on Dell XPS 12 9Q23, Adhesive tape: paso 6, imagen 1 de 1
    • We removed the battery to avoid electric shocks.
    • Remove the adhesive tape.
  7. Replacement the hard disk on Dell XPS 12 9Q23, Remove the hard disk drive: paso 7, imagen 1 de 2 Replacement the hard disk on Dell XPS 12 9Q23, Remove the hard disk drive: paso 7, imagen 2 de 2
    • Remove the screw with a #00 Phillips screwdriver.
    • Remove the hard disk from its location.
Conclusión
To reassemble your device, follow the instructions in reverse order.
2 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
¡ Schwarzer nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Schwarzer
Miembro Desde 08/07/19
5,029 Reputación
13 Guías creadas
Equipo
i.Fixit FR Team Miembro de i.Fixit FR Team
Community
Miembros de 3
40 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 25
Todo El Tiempo: 1,961
