Saltar al contenido principal
Realigning 12-Inch Bionaire Fan Metal Coil
Hemish Patel
Hemish Patel y 2 otros contribuidores
Última actualización: February 19, 2016
15 minuto
Fácil
Introducción
Ir al paso 1
Annoyed by the fact that your fan won't stay in a desired, fixed position? This fast fix guide will help correct that problem in no time!
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: paso 1, imagen 1 de 2 Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: paso 1, imagen 2 de 2
    • Unlock all of the tabs holding the fan cage together.
    • Carefully pull off the cage.
  2. Realigning 12-Inch Bionaire Fan Metal Coil: paso 2, imagen 1 de 2 Realigning 12-Inch Bionaire Fan Metal Coil: paso 2, imagen 2 de 2
    • Using a Phillips #2 screwdriver, untighten the 1/4'' screw that is located underneath the fan blade.
    • Blade may be sharp so watch out!
    • Cautiously remove the blade from the hinge.
    • Put the screws in a cup so you don't lose them!
  3. Realigning 12-Inch Bionaire Fan Metal Coil: paso 3, imagen 1 de 2 Realigning 12-Inch Bionaire Fan Metal Coil: paso 3, imagen 2 de 2
    • Rotate the black cap counter-clockwise to disconnect it from the back fan cage.
    • Pull off the back cage from the engine holder.
  4. Realigning 12-Inch Bionaire Fan Metal Coil: paso 4, imagen 1 de 1
    • Working with the Phillips #2 screwdriver, loosen the 1/4'' center hinge screw from the metal base.
  5. Realigning 12-Inch Bionaire Fan Metal Coil: paso 5, imagen 1 de 2 Realigning 12-Inch Bionaire Fan Metal Coil: paso 5, imagen 2 de 2
    • Using the Phillips #2 screwdriver, separate the wire holder from the back of black cover by removing the two 1/8'' screws.
  6. Realigning 12-Inch Bionaire Fan Metal Coil: paso 6, imagen 1 de 2 Realigning 12-Inch Bionaire Fan Metal Coil: paso 6, imagen 2 de 2
    • Pull of the black knob by rotating the knob counter-clockwise.
    • Pull down the black cover all the way.
    • The coil may pop out after removing the cover.
  7. Realigning 12-Inch Bionaire Fan Metal Coil: paso 7, imagen 1 de 2 Realigning 12-Inch Bionaire Fan Metal Coil: paso 7, imagen 2 de 2
    • Take out the gold metal spring.
    • Realign the metal coil into designated space.
    • Push the coil in with some force so it rests perfectly in the space.
    • To make placing the coil back in more easier, use the screwdriver!
  8. Realigning 12-Inch Bionaire Fan Metal Coil: paso 8, imagen 1 de 2 Realigning 12-Inch Bionaire Fan Metal Coil: paso 8, imagen 2 de 2
    • Align the end of the metal coil into the same hole the black wire comes out of in the black cover from step 6.
    • This can be a frustrating step. Be patient!
Conclusión
3 personas más completaron esta guía.
Hemish Patel
Miembro Desde 09/29/15
231 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-3, Green Fall 2015 Miembro de Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
4 Miembros
4 Guías creadas
Un comentario
I have a fan It hum I have to spin the blade for it to start spin
Chris - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 3,935
