Saltar al contenido principal
Razer Blade Stealth 2017 Motherboard Replacement
Aiden Vu
Aiden Vu y 2 otros contribuidores
Última actualización: June 19, 2024
45 minuto
Moderado
Pasos faltantes
Introducción
Ir al paso 1
This guide outlines how to remove the motherboard in the Razer Blade Stealth 2017. Motherboard replacement may be necessary if the motherboard fails due to power surge or outage, overheating, or the use of faulty components. Some tools are required for this replacement.
Qué necesitas
Partes
Herramientas
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Razer Blade Stealth 2017 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Razer Blade Stealth 2017 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Motherboard Replacement: paso 3, imagen 1 de 2 Razer Blade Stealth 2017 Motherboard Replacement: paso 3, imagen 2 de 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Motherboard Replacement: paso 5, imagen 1 de 2 Razer Blade Stealth 2017 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Motherboard Replacement, Fan: paso 6, imagen 1 de 2 Razer Blade Stealth 2017 Motherboard Replacement, Fan: paso 6, imagen 2 de 2
    • Use a plastic spudger to lift the white clasp on the fan connector.
  7. Razer Blade Stealth 2017 Motherboard Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to pull the fan cable out of the opened connector terminal.
  8. Razer Blade Stealth 2017 Motherboard Replacement: paso 8, imagen 1 de 3 Razer Blade Stealth 2017 Motherboard Replacement: paso 8, imagen 2 de 3 Razer Blade Stealth 2017 Motherboard Replacement: paso 8, imagen 3 de 3
    • Use tweezers to squeeze the fan's white header.
    • Disconnect the fan connector by sliding it out toward the rear of the chassis.
  9. Razer Blade Stealth 2017 Motherboard Replacement: paso 9, imagen 1 de 3 Razer Blade Stealth 2017 Motherboard Replacement: paso 9, imagen 2 de 3 Razer Blade Stealth 2017 Motherboard Replacement: paso 9, imagen 3 de 3
    • Remove any tape attached to the fans.
    • Use a Phillips #00 screwdriver to remove the six, 3mm screws and the metal bracket around both fans.
  10. Razer Blade Stealth 2017 Motherboard Replacement: paso 10, imagen 1 de 2 Razer Blade Stealth 2017 Motherboard Replacement: paso 10, imagen 2 de 2
    • Use a plastic spudger to slide the fans out of the case.
  11. Razer Blade Stealth 2017 Motherboard Replacement, Motherboard: paso 11, imagen 1 de 3 Razer Blade Stealth 2017 Motherboard Replacement, Motherboard: paso 11, imagen 2 de 3 Razer Blade Stealth 2017 Motherboard Replacement, Motherboard: paso 11, imagen 3 de 3
    • Use a plastic spudger to gently undo the connections to the motherboard.
  12. Razer Blade Stealth 2017 Motherboard Replacement: paso 12, imagen 1 de 3 Razer Blade Stealth 2017 Motherboard Replacement: paso 12, imagen 2 de 3 Razer Blade Stealth 2017 Motherboard Replacement: paso 12, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws holding the display hinges on both side.
    • Remove the small plastic brackets holding the display hinges.
  13. Razer Blade Stealth 2017 Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the 2.6 mm screw holding the Wi-Fi card down with a Phillips #00 screwdriver.
    • Remove the motherboard from the laptop.
Conclusión
To reassemble your device, follow these instructions in reverse order. Ensure that your laptop boots into BIOS for any necessary configuration after installing a new motherboard.
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 187
