Saltar al contenido principal
Razer Blade Stealth 2017 Audio and USB-A Port Replacement
Helene Willits
Helene Willits y 6 otros contribuidores
Última actualización: October 21, 2021
15 minuto
Moderado
Introducción
Ir al paso 1
This guide outlines how to replace the audio and USB-A port module in the Razer Blade Stealth 2017. The audio may be faint or not work. This module is found on the left-hand side of the laptop and often has issues regarding loose ports and external device communication. Some tools are required for this replacement.
Qué necesitas
Herramientas
Ver más…
  1. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: paso 1, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: paso 1, imagen 2 de 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 2, imagen 1 de 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 3, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 3, imagen 2 de 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 5, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 5, imagen 2 de 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: paso 6, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: paso 6, imagen 2 de 2
    • Use a plastic spudger to lift up the module connector.
  7. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 7, imagen 1 de 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
  8. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: paso 8, imagen 1 de 1
    • Use a plastic spudger to remove the USB-A and audio port module from the chassis.
Conclusión
Una persona más ha completado esta guía.
Helene Willits
Miembro Desde 10/10/19
776 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S11-G3, Regan Fall 2019 Miembro de Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
Miembros de 4
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,798
