Saltar al contenido principal
Razer Blade Stealth 2016 Hard Drive Replacement
Lindsay Grant
Lindsay Grant y 7 otros contribuidores
Última actualización: November 15, 2022
7 - 20 minutos
Fácil
Necesita más imágenes
Introducción
Ir al paso 1
The hard drive is vital in any laptop as it stores all your data and if it does not work properly then you can lose out on all your important photos and data.
The hard drive might not be functioning correctly if your laptop says there is no hard drive detected or the computer crashes constantly.
Follow this guide to replace the hard drive on your Razer Blade Stealth 2016.
Make sure the laptop is powered off before beginning this guide.
Qué necesitas
Kits de reparación
Estos kits contienen todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: paso 2, imagen 1 de 1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: paso 3, imagen 1 de 1
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: paso 4, imagen 1 de 1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: paso 5, imagen 1 de 2 Razer Blade Stealth 2016 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: paso 6, imagen 1 de 2 Razer Blade Stealth 2016 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Carefully slide the hard drive out from its slot.
Conclusión
Una persona más ha completado esta guía.
Lindsay Grant
Miembro Desde 10/10/19
403 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G4, Leahy Fall 2019 Miembro de USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 19
Ultimos 30 días: 31
Todo El Tiempo: 3,021
