Saltar al contenido principal
Razer Basilisk V3 Left and Right Click Buttons Replacement
Brendin Costa
Brendin Costa y 2 otros contribuidores
Última actualización: May 22, 2024
15 minuto
Moderado
Introducción
Ir al paso 1
This guide outlines the steps for replacing the main left and right-click buttons on the Razer Basilisk V3 gaming mouse. Whether the buttons have become unresponsive or physically damaged, this guide will assist with installing new button modules to restore functionality.
Qué necesitas
Herramientas
Ver más…
  1. Razer Basilisk V3 Left and Right Click Buttons Replacement, Skates: paso 1, imagen 1 de 1
    • Locate each of the skates.
  2. Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 2, imagen 1 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 2, imagen 2 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 2, imagen 3 de 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Left and Right Click Buttons Replacement, Backplate: paso 3, imagen 1 de 1
    • Remove two 4.8 mm screws that were hidden under the skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 4, imagen 1 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 4, imagen 2 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 4, imagen 3 de 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 5, imagen 1 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 5, imagen 2 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 5, imagen 3 de 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
  6. Razer Basilisk V3 Left and Right Click Buttons Replacement, Scroll Wheel Assembly: paso 6, imagen 1 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement, Scroll Wheel Assembly: paso 6, imagen 2 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement, Scroll Wheel Assembly: paso 6, imagen 3 de 3
    • Use the flat end of the spudger to pop-out the scroll wheel assembly.
    • Make sure you are careful when removing the assembly since it is still connected to the device with a ribbon cable. If you pull too hard the cable could break.
  7. Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 7, imagen 1 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 7, imagen 2 de 3 Razer Basilisk V3 Left and Right Click Buttons Replacement: paso 7, imagen 3 de 3
    • Pull up on the top half of the cable connector and pull the cable from the connector.
    • The connection pins on the wire face towards the scroll wheel assembly housing. When reassembling, make sure the connectors on the cable are facing the correct direction.
  8. Razer Basilisk V3 Left and Right Click Buttons Replacement, Left and Right Click Buttons: paso 8, imagen 1 de 1
    • Use the flat end of the spudger to press the two main button modules out from their mountings.
    • Apply steady pressure to just the button modules to avoid damaging the surrounding plastic.
Conclusión
Brendin Costa
Miembro Desde 03/18/24
402 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 1-2, Santin Spring 2024 Miembro de UMass Dartmouth, Team 1-2, Santin Spring 2024
UMASSD-SANTIN-S24S1G2
3 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 33
Ultimos 30 días: 136
Todo El Tiempo: 1,217
