Saltar al contenido principal
Raspberry Pi 3 SD Card Replacement
ΛΛKΛRΞT
ΛΛKΛRΞT y 2 otros contribuidores
Última actualización: October 4, 2024
35 segundo - 5 minuto
Fácil
Guía aportada por comunidad
Introducción
Ir al paso 1
In this guide I will show you how to change SD card in your Raspberry Pi 3.
Qué necesitas
Partes
Herramientas
  1. Raspberry Pi 3 SD Card Replacement, Raspberry Pi 3 SD Card replacement.: paso 1, imagen 1 de 1
    • The Raspberry Pi 3 should look like this closed.
  2. Raspberry Pi 3 SD Card Replacement, Top cover removal: paso 2, imagen 1 de 1
    • Open the top lid like I have done on the image.
    • The top is marked that you are gonna remove in the next step.
  3. Raspberry Pi 3 SD Card Replacement, Cover for GPIO Hider and IO Shield removal: paso 3, imagen 1 de 1
    • Now remove the cover for the two covers.
    • It should look like the image.
    • I have marked the covers for the next step.
  4. Raspberry Pi 3 SD Card Replacement, IO Shield and GPIO Hider removal: paso 4, imagen 1 de 1
    • Remove the two sides.
  5. Raspberry Pi 3 SD Card Replacement, Removal.: paso 5, imagen 1 de 2 Raspberry Pi 3 SD Card Replacement, Removal.: paso 5, imagen 2 de 2
    • Now we should successfully have removed the case.
    • Notice that the side shown on the first image is the one that we are intrested in.
    • When we have flipped the Pi 3 over we can remove the SD card.
Conclusión
5 personas más completaron esta guía.
ΛΛKΛRΞT
Miembro Desde 11/22/17
229 Reputación
1 Guía escrita
Un comentario
On the official RPi case there’s a cutout where the SD card inserts. This is a pointless guide to be honest.
Stephen Wilson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 21
Todo El Tiempo: 2,148
