Saltar al contenido principal
Polaroid SNAP Battery Replacement
Ian Colantuoni
Ian Colantuoni y 2 otros contribuidores
Última actualización: July 13, 2022
15 minuto
Moderado
Introducción
Ir al paso 1
When replacing the battery, realize that there is an adhesive which binds the battery to the camera. Given the adhesive, force might be required to remove the battery. However, you should be able to remove it with your hands.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Polaroid SNAP Battery Replacement, Polaroid SNAP Front and Back Face Plate Removal: paso 1, imagen 1 de 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Battery Replacement: paso 2, imagen 1 de 2 Polaroid SNAP Battery Replacement: paso 2, imagen 2 de 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Battery Replacement: paso 3, imagen 1 de 2 Polaroid SNAP Battery Replacement: paso 3, imagen 2 de 2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Battery Replacement: paso 4, imagen 1 de 3 Polaroid SNAP Battery Replacement: paso 4, imagen 2 de 3 Polaroid SNAP Battery Replacement: paso 4, imagen 3 de 3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Battery Replacement: paso 5, imagen 1 de 1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Two foam strips and adhesive glue binds the battery to the camera.
  7. Polaroid SNAP Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery by lifting up the battery from the left corner. If you can not remove the battery with your hands, consider using a Plastic Opening Tool
  8. Polaroid SNAP Battery Replacement: paso 8, imagen 1 de 2 Polaroid SNAP Battery Replacement: paso 8, imagen 2 de 2
    • Using your fingers, remove the five pin connector from the device.
Conclusión
15 personas más completaron esta guía.
Equipo
USF Tampa, Team 7-3, Cheng Spring 2016 Miembro de USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Miembros
19 Guías creadas
24 comentarios
Thank you so much for showing me how to do this. FYI: For the digital LCD screen version of this camera, there is only one screw to take out on that first step.
Can you tell me where I can buy the replacement battery for this camera? Thanks.
Tommy Li - Contestar
I would like to know where to buy it too.
Giorgina Nardi - Contestar
Same question need to know where to purchase a new battery and is this a common issue for the snap touch
Anita Guzman - Contestar
I also need a battery and it seems almost impossible to find one to buy. Please let me know if anybody has found a replacement battery that fits.
Jaco Botha - Contestar
Has anyone managed to find where to buy a replacement battery?
ajm.smith - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 26
Ultimos 7 días: 164
Ultimos 30 días: 712
Todo El Tiempo: 69,794
