Saltar al contenido principal
Philips Sonicare ProtectiveClean 6500 Battery Replacement
Liam Casto
Liam Casto y 2 otros contribuidores
Última actualización: June 21, 2024
15 minuto
Moderado
Introducción
Ir al paso 1
If your Philips Sonicare ProtectiveClean 6500 isn’t powering on, has intermittent power, or not holding charge, use this guide to replace the battery.
Qué necesitas
Herramientas
  1. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: paso 1, imagen 1 de 3 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: paso 1, imagen 2 de 3 Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: paso 1, imagen 3 de 3
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 2, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 2, imagen 2 de 2
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 3, imagen 1 de 2 Philips Sonicare ProtectiveClean 6500 Battery Replacement: paso 3, imagen 2 de 2
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Use an opening tool to gently pry up the battery.
    • Remove the battery.
Conclusión
Liam Casto
Miembro Desde 04/01/24
354 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-4, Harley Spring 2024 Miembro de IUPUI, Team 1-4, Harley Spring 2024
IUPUI-HARLEY-S24S1G4
3 Miembros
3 Guías creadas
2 comentarios
Hello, thanks for your tutorial!
Is there others Sonicare models like this one where you don't have to desold the battery ?
Julien CHAZAL - Contestar
It doesn’t appear you have to desolder the battery with this model. I think the diamond clean does require desoldering though.
Jacob Poole -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 249
