Saltar al contenido principal
Philips Sonicare 2 Series Motor Replacement
Jonathan Jarvis
Jonathan Jarvis y 4 otros contribuidores
Última actualización: March 10, 2019
20 minuto - 1 hora
Difícil
Fotos de acción
Necesita mejores imágenes
Pasos faltantes
Introducción
Ir al paso 1
This guide is for the Philips Sonicare 2 series HX6211/46 toothbrush. It shows you how to replace the motor for this toothbrush. He is a link for a guide how to soldering which will be needed for this guide. Cómo soldar y desoldar conexiones
Qué necesitas
Partes
Herramientas
Ver más…
  1. Philips Sonicare 2 Series Motor Replacement, Philips Sonicare 2 Series Disassembly: paso 1, imagen 1 de 1
    • Pull upwards to remove the brush head from the top of the device.
  2. Philips Sonicare 2 Series Motor Replacement: paso 2, imagen 1 de 1
    • Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
  3. Philips Sonicare 2 Series Motor Replacement: paso 3, imagen 1 de 2 Philips Sonicare 2 Series Motor Replacement: paso 3, imagen 2 de 2
    • Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
    • Be very careful not to damage the charging port during this step. Otherwise you will have to solder this part back to the device as shown in the second figure.
  4. Philips Sonicare 2 Series Motor Replacement: paso 4, imagen 1 de 1
    • Next you will be able to remove the internal electronic mechanism as shown in the figure.
  5. Philips Sonicare 2 Series Motor Replacement: paso 5, imagen 1 de 1
    • Remove the white battery cover as shown in the figure.
  6. Philips Sonicare 2 Series Motor Replacement: paso 6, imagen 1 de 1
    • Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
  7. Philips Sonicare 2 Series Motor Replacement, Motor: paso 7, imagen 1 de 1
    • Disassemble the device. Remove the plastic piece over the brush attachment as shown. Object can be removed by hand as shown. No tool is required.
  8. Philips Sonicare 2 Series Motor Replacement: paso 8, imagen 1 de 1
    • Desolder the motor from the circuit board at the two locations shown.
  9. Philips Sonicare 2 Series Motor Replacement: paso 9, imagen 1 de 1
    • Remove the bad motor.
Linea de Meta
Equipo
IUPUI, Team S6-G2, Baechle Fall 2017 Miembro de IUPUI, Team S6-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G2
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 31
Todo El Tiempo: 2,811
