Saltar al contenido principal
Palm m105 Batteries Replacement
Erik Thompson
Erik Thompson y 6 otros contribuidores
Última actualización: July 16, 2021
25 segundo
Muy fácil
Fotos de acción
Necesita mejores imágenes
Bordeador de Pasos
Introducción
Ir al paso 1
You will need to have a supply of AAA batteries for replacement. Can be found at most hardware and department stores. You can also order them online here
  1. Palm m105 Batteries Replacement, Batteries: paso 1, imagen 1 de 1
    • Press the latch on the battery door on the back of the device and pull outwards.
    • Back the device up if possible, you may lose all your data if there is no power for a little too long for it to retain it, make sure this is done quickly.
  2. Palm m105 Batteries Replacement: paso 2, imagen 1 de 1
    • Install two AAA alkaline batteries into the battery compartment, placing the positive and negative ends of the battery in the correct positions. (Shown as a diagram inside the battery compartment)
    • Make sure to remove one battery at a time and replace with fresh battery. This will retain information on the device.
  3. Palm m105 Batteries Replacement: paso 3, imagen 1 de 1
    • Place the battery door back into place on the back of the device; it will make a 'click' sound when properly reattached.
Conclusión
Erik Thompson
Miembro Desde 10/04/11
31 Reputación
5 Guías creadas
Equipo
UW Stout, Team 1-3, Zhou Fall 2011 Miembro de UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
Miembros de 4
7 Guías creadas
2Guía Comentarios
"Moderate difficulty"?? There's only three steps and two of them involve removing and reinstalling the battery door.
Gene Merritt - Contestar
I have on that doesn't use batteries. It's a rechargeable one. Do you have any instructions on how to replace the internal battery?
deanplays - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,294
