Saltar al contenido principal
Olympus SZ-12 Back Case Replacement
Samuel Hays
Samuel Hays y otro contribuidor
Última actualización: September 10, 2020
15 minuto
Fácil
Necesita más imágenes
Introducción
Ir al paso 1
You will need a clean, well-lit area, an iFixit repair kit including the specialized screw driver, along with the Phillips #000 bit. We also recommend you have an organization tray in order to keep track of all the screws you will be taking out.
Qué necesitas
Herramientas
  1. Olympus SZ-12 Back Case Replacement, Back Case: paso 1, imagen 1 de 2 Olympus SZ-12 Back Case Replacement, Back Case: paso 1, imagen 2 de 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 Back Case Replacement: paso 2, imagen 1 de 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 Back Case Replacement: paso 3, imagen 1 de 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 Back Case Replacement: paso 4, imagen 1 de 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 Back Case Replacement: paso 5, imagen 1 de 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 Back Case Replacement: paso 6, imagen 1 de 1
    • Using the blue plastic opening tool, wedge open and remove the case.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 583
