Introducción
Learn how to install the power button on the OLPC XO-4 laptop.
Herramientas
Partes
No se especificaron partes.
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Gently pull out the two antenna connectors by pulling them away from the motherboard.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Remove the power button by pinching in the four tabs until the power button can be pushed out.
Casi Terminas!
Conclusión
