Saltar al contenido principal
Nokia XL Dual Sim Rear Camera Replacement
Shadeed Bilal
Shadeed Bilal y 6 otros contribuidores
Última actualización: May 7, 2024
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to restore your ability to digitally capture the world by replacing a broken or non-working rear facing camera on your Nokia XL Dual Sim.
Qué necesitas
Herramientas
Ver más…
  1. Nokia XL Dual Sim Rear Camera Replacement, Back Cover Removal: paso 1, imagen 1 de 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: paso 2, imagen 1 de 2 Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: paso 2, imagen 2 de 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: paso 3, imagen 1 de 2 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: paso 3, imagen 2 de 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: paso 4, imagen 1 de 3 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: paso 4, imagen 2 de 3 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: paso 4, imagen 3 de 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Rear Camera Replacement, System components: paso 5, imagen 1 de 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: paso 6, imagen 1 de 2 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • With tweezers, gently release the rear camera motherboard connector.
  7. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: paso 7, imagen 1 de 3 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: paso 7, imagen 2 de 3 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: paso 7, imagen 3 de 3
    • Gently pull the motherboard connector upward to remove the rear camera component.
Conclusión
Una persona más ha completado esta guía.
Shadeed Bilal
Miembro Desde 09/25/14
231 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 1-4, Brown Fall 2014 Miembro de USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
Miembros de 3
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 11
Ultimos 30 días: 13
Todo El Tiempo: 797
