Saltar al contenido principal
Nokia 6030 Keypad Replacement
Spencer Woodworth
Spencer Woodworth y 4 otros contribuidores
Última actualización: May 24, 2022
5 minuto
Fácil
Introducción
Ir al paso 1
If your Nokia 6030’s keypad works inconsistently, you may need to replace the old keypad with a new one.
After extended use, cell phone keypads become unresponsive. A faulty keypad causes frustrating experiences when attempting to type something on the device or to call someone.
This guide provides step-by-step instructions on replacing your Nokia 6030’s keypad, without the need for any special skills or tools.
  1. Nokia 6030 Keypad Replacement, Battery: paso 1, imagen 1 de 3 Nokia 6030 Keypad Replacement, Battery: paso 1, imagen 2 de 3 Nokia 6030 Keypad Replacement, Battery: paso 1, imagen 3 de 3
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Nokia 6030 Keypad Replacement: paso 2, imagen 1 de 3 Nokia 6030 Keypad Replacement: paso 2, imagen 2 de 3 Nokia 6030 Keypad Replacement: paso 2, imagen 3 de 3
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Nokia 6030 Keypad Replacement, SIM Card: paso 3, imagen 1 de 3 Nokia 6030 Keypad Replacement, SIM Card: paso 3, imagen 2 de 3 Nokia 6030 Keypad Replacement, SIM Card: paso 3, imagen 3 de 3
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Nokia 6030 Keypad Replacement: paso 4, imagen 1 de 1
    • Use your finger to close the metal cage.
  5. Nokia 6030 Keypad Replacement, Front Cover: paso 5, imagen 1 de 3 Nokia 6030 Keypad Replacement, Front Cover: paso 5, imagen 2 de 3 Nokia 6030 Keypad Replacement, Front Cover: paso 5, imagen 3 de 3
    • Insert your two fingers under the two tabs found at the top of the phone underneath the black casing, then pull the casing up and slide it out slowly.
  6. Nokia 6030 Keypad Replacement: paso 6, imagen 1 de 2 Nokia 6030 Keypad Replacement: paso 6, imagen 2 de 2
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Nokia 6030 Keypad Replacement: paso 7, imagen 1 de 3 Nokia 6030 Keypad Replacement: paso 7, imagen 2 de 3 Nokia 6030 Keypad Replacement: paso 7, imagen 3 de 3
    • Use your fingers to slowly lift the screen back towards the bottom of the phone using the arrows found at the top of the phone.
  8. Nokia 6030 Keypad Replacement, Keypad: paso 8, imagen 1 de 2 Nokia 6030 Keypad Replacement, Keypad: paso 8, imagen 2 de 2
    • Gently pull the rubber away from the front screen and the buttons will detach from the plastic case.
  9. Nokia 6030 Keypad Replacement: paso 9, imagen 1 de 2 Nokia 6030 Keypad Replacement: paso 9, imagen 2 de 2
    • Remove old keypad and replace it with new keypad.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 23-63, Johann Spring 2010 Miembro de Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
Miembros de 3
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 2,809
