Saltar al contenido principal
Nokia 3120 Liquid Crystal Display (LCD) Replacement
Pierre Tong
Pierre Tong y 4 otros contribuidores
Última actualización: September 9, 2017
Sin estimación
Moderado
Introducción
Ir al paso 1
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
Qué necesitas
Herramientas
  1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: paso 1, imagen 1 de 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: paso 1, imagen 2 de 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: paso 1, imagen 3 de 3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: paso 2, imagen 1 de 1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: paso 3, imagen 1 de 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: paso 3, imagen 2 de 3 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: paso 3, imagen 3 de 3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Liquid Crystal Display (LCD): paso 4, imagen 1 de 1
    • Once the cover plate has been removed, the keypad should easily pop out.
  5. Nokia 3120 Liquid Crystal Display (LCD) Replacement: paso 5, imagen 1 de 2 Nokia 3120 Liquid Crystal Display (LCD) Replacement: paso 5, imagen 2 de 2
    • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  6. Nokia 3120 Liquid Crystal Display (LCD) Replacement: paso 6, imagen 1 de 1
    • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  7. Nokia 3120 Liquid Crystal Display (LCD) Replacement: paso 7, imagen 1 de 1
    • Take out the cell phone electronic board
  8. Nokia 3120 Liquid Crystal Display (LCD) Replacement: paso 8, imagen 1 de 1
    • The LCD screen can now be removed from the body of the phone.
Conclusión
2 personas más completaron esta guía.
Pierre Tong
Miembro Desde 03/11/13
92 Reputación
4 Guías creadas
Equipo
Clemson, Team 13-2, Benson Spring 2013 Miembro de Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,468
