Saltar al contenido principal
Nokia 1100b RH-36 Screen Replacement
JSwan
JSwan y 2 otros contribuidores
Última actualización: September 8, 2017
5 minuto
Fácil
Guía de Estudiante Destacada
Introducción
Ir al paso 1
Use this guide to replace the screen in your phone.
Qué necesitas
Herramientas
  1. Nokia 1100b RH-36 Screen Replacement, Battery Cover: paso 1, imagen 1 de 2 Nokia 1100b RH-36 Screen Replacement, Battery Cover: paso 1, imagen 2 de 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Screen Replacement, Battery: paso 2, imagen 1 de 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Screen Replacement, Front Cover: paso 3, imagen 1 de 2 Nokia 1100b RH-36 Screen Replacement, Front Cover: paso 3, imagen 2 de 2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  4. Nokia 1100b RH-36 Screen Replacement, Inner Casing: paso 4, imagen 1 de 2 Nokia 1100b RH-36 Screen Replacement, Inner Casing: paso 4, imagen 2 de 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  5. Nokia 1100b RH-36 Screen Replacement, Screen: paso 5, imagen 1 de 2 Nokia 1100b RH-36 Screen Replacement, Screen: paso 5, imagen 2 de 2
    • Flip over the metal frame you just removed.
    • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
    • Remove the screen bearing plastic frame.
Conclusión
2 personas más completaron esta guía.
JSwan
Miembro Desde 04/12/13
781 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-43, Amido Spring 2013 Miembro de Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
Miembros de 4
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 36
Todo El Tiempo: 2,024
