Saltar al contenido principal
Nobis NB07 Microphone Replacement
Daniel Gomero
Daniel Gomero y 4 otros contribuidores
Última actualización: May 7, 2024
25 - 35 minutos
Difícil
Introducción
Ir al paso 1
If your tablet microphone is not working at its best, you can replace it easily using this guide. To do so, you will need to disassemble your tablet and use soldering tools.
Qué necesitas
Herramientas
Ver más…
  1. Nobis NB07 Microphone Replacement, Opening the case: paso 1, imagen 1 de 1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Microphone Replacement: paso 2, imagen 1 de 3 Nobis NB07 Microphone Replacement: paso 2, imagen 2 de 3 Nobis NB07 Microphone Replacement: paso 2, imagen 3 de 3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Microphone Replacement, Replacing the battery: paso 3, imagen 1 de 3 Nobis NB07 Microphone Replacement, Replacing the battery: paso 3, imagen 2 de 3 Nobis NB07 Microphone Replacement, Replacing the battery: paso 3, imagen 3 de 3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Microphone Replacement: paso 4, imagen 1 de 3 Nobis NB07 Microphone Replacement: paso 4, imagen 2 de 3 Nobis NB07 Microphone Replacement: paso 4, imagen 3 de 3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Microphone Replacement: paso 5, imagen 1 de 1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Microphone Replacement: paso 6, imagen 1 de 2 Nobis NB07 Microphone Replacement: paso 6, imagen 2 de 2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Microphone Replacement, Removing the cameras: paso 7, imagen 1 de 3 Nobis NB07 Microphone Replacement, Removing the cameras: paso 7, imagen 2 de 3 Nobis NB07 Microphone Replacement, Removing the cameras: paso 7, imagen 3 de 3
    • Remove the black tape covering the cameras power cable.
  8. Nobis NB07 Microphone Replacement: paso 8, imagen 1 de 2 Nobis NB07 Microphone Replacement: paso 8, imagen 2 de 2
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. Nobis NB07 Microphone Replacement: paso 9, imagen 1 de 3 Nobis NB07 Microphone Replacement: paso 9, imagen 2 de 3 Nobis NB07 Microphone Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
  10. Nobis NB07 Microphone Replacement, Removing the microphone: paso 10, imagen 1 de 1
    • Locate the microphone's cables in front of the cameras' ZIF connector.
  11. Nobis NB07 Microphone Replacement: paso 11, imagen 1 de 1
  12. Nobis NB07 Microphone Replacement: paso 12, imagen 1 de 2 Nobis NB07 Microphone Replacement: paso 12, imagen 2 de 2
    • Use the pointy end of the tweezers to retrieve the microphone from its socket.
    • You can now remove the microphone.
Conclusión
Daniel Gomero
Miembro Desde 01/21/15
966 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 5-5, Brown Winter 2015 Miembro de USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 160
