Saltar al contenido principal
Nixon Mission Android Wear Battery Replacement
Mauricio Ambrosio
Mauricio Ambrosio y 4 otros contribuidores
Última actualización: March 19, 2020
10 - 20 minutos
Moderado
Fotos de acción
Herramientas Incorrectas
Introducción
Ir al paso 1
Batteries tend to lose capacity over time. This guide will show you how to replace the battery of your Nixon Mission Android Wear.
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Nixon Mission Android Wear Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: paso 2, imagen 1 de 1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: paso 3, imagen 1 de 1
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: paso 4, imagen 1 de 1
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: paso 5, imagen 1 de 1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: paso 6, imagen 1 de 1
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: paso 7, imagen 1 de 1
    • Carefully remove the battery from the watch.
Conclusión
7 personas más completaron esta guía.
Equipo
IUPUI, Team S3-G2, Harley Fall 2017 Miembro de IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
Miembros de 3
3 Guías creadas
20 comentarios
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - Contestar
same here, where to purchase a replacement battery ?
peter.erdogyaraki - Contestar
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - Contestar
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - Contestar
After an extensive search there doesn't seem to be any info out there about battery size…..still
Jerry Jerry J - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 34
Todo El Tiempo: 6,898
