Nikon Coolpix S9050 Motherboard Replacement
Introducción
Ir al paso 1The motherboard is the central hub for communication between all of the components in a device. If more than one component is failing to work, the motherboard may be faulty and needs to be replaced. This guide will assist you in replacing the motherboard on the Nikon Coolpix S9050.
Qué necesitas
Herramientas
Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
Remove the two 3.2 mm silver screws on either side of the display screen using a Phillips #000 screwdriver.
Use a spudger to detach the display ribbon cable and remove the display screen.
Una persona más ha completado esta guía.
