Saltar al contenido principal
Nikon Coolpix S9050 Motherboard Replacement
Kyle Gildner
Kyle Gildner y 6 otros contribuidores
Última actualización: January 9, 2025
30 minuto - 1 hora
Moderado
Introducción
Ir al paso 1
The motherboard is the central hub for communication between all of the components in a device. If more than one component is failing to work, the motherboard may be faulty and needs to be replaced. This guide will assist you in replacing the motherboard on the Nikon Coolpix S9050.
Qué necesitas
Herramientas
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
  1. Nikon Coolpix S9050 Motherboard Replacement, Menu Wheel and OK Button: paso 1, imagen 1 de 3 Nikon Coolpix S9050 Motherboard Replacement, Menu Wheel and OK Button: paso 1, imagen 2 de 3 Nikon Coolpix S9050 Motherboard Replacement, Menu Wheel and OK Button: paso 1, imagen 3 de 3
    • Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
    • Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
  2. Nikon Coolpix S9050 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the display frame and trim from the main body of the camera.
  3. Nikon Coolpix S9050 Motherboard Replacement: paso 3, imagen 1 de 3 Nikon Coolpix S9050 Motherboard Replacement: paso 3, imagen 2 de 3 Nikon Coolpix S9050 Motherboard Replacement: paso 3, imagen 3 de 3
    • Press down and pull the Menu Wheel/OK Button panel toward the screen.
    • This releases the panel from the slots.
  4. Nikon Coolpix S9050 Motherboard Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S9050 Motherboard Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S9050 Motherboard Replacement: paso 4, imagen 3 de 3
    • Lift the black plastic tabs, which are securing the panel.
    • Gently pull the panel out to separate the display ribbon cable from the camera body.
  5. Nikon Coolpix S9050 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Nikon Coolpix S9050 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Nikon Coolpix S9050 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Remove the two 3.2 mm silver screws on either side of the display screen using a Phillips #000 screwdriver.
    • Use a spudger to detach the display ribbon cable and remove the display screen.
  6. Nikon Coolpix S9050 Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the three 3.2 mm silver screws surrounding the metal panel using a Phillips #000 screwdriver.
  7. Nikon Coolpix S9050 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the two 3.2 mm silver screws from both of the side panels using a Phillips #000 screwdriver.
  8. Nikon Coolpix S9050 Motherboard Replacement: paso 8, imagen 1 de 3 Nikon Coolpix S9050 Motherboard Replacement: paso 8, imagen 2 de 3 Nikon Coolpix S9050 Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the metal panel from the body and use the spudger to detach the three ribbon wires attached to the motherboard.
    • Remove the two 3.2 mm silver screws, which secure the motherboard using a Phillips #000 screwdriver.
    • Lift and remove the motherboard from the camera body.
    • The AV port will be attached to the motherboard.
Conclusión
Una persona más ha completado esta guía.
Kyle Gildner
Miembro Desde 11/05/19
199 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G5, Stella Fall 2019 Miembro de IUPUI, Team S1-G5, Stella Fall 2019
IUPUI-STELLA-F19S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 309
