Nikon Coolpix S9050 Menu Wheel and OK Button Replacement
Introducción
Ir al paso 1If your Nikon Coolpix S9050 is not turning on, the menu wheel and OK button may need to be replaced. The requirements for this procedure are to have a Phillips #000 screwdriver and a flat surface to disassemble the parts. Make sure the camera is off and it is recommended to work in a dry area.
Qué necesitas
Herramientas
Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
Una persona más ha completado esta guía.
