Saltar al contenido principal
Nikon Coolpix S9050 LCD Screen Replacement
Kyle Gildner
Kyle Gildner y 3 otros contribuidores
Última actualización: August 13, 2020
10 minuto
Moderado
Necesita mejores imágenes
Introducción
Ir al paso 1
Overtime, the components in a camera are likely to fail or become faulty. One component that may become faulty overtime is the screen. If your camera is not properly displaying the images you’ve taken or if there are dead pixels on your screen, the screen may need to be replaced. This guide will assist you in replacing the LCD Screen on the Nikon Coolpix S9050.
Qué necesitas
Partes
Herramientas
  • Phillips #000 Screwdriver
  • Spudger
    Spudger
Ver más…
  1. Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: paso 1, imagen 1 de 3 Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: paso 1, imagen 2 de 3 Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: paso 1, imagen 3 de 3
    • Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
    • Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
  2. Nikon Coolpix S9050 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the display frame and trim from the main body of the camera.
  3. Nikon Coolpix S9050 LCD Screen Replacement: paso 3, imagen 1 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 3, imagen 2 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 3, imagen 3 de 3
    • Press down and pull the Menu Wheel/OK Button panel toward the screen.
    • This releases the panel from the slots.
  4. Nikon Coolpix S9050 LCD Screen Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S9050 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Lift the black plastic tabs, which are securing the panel.
    • Gently pull the panel out to separate the display ribbon cable from the camera body.
  5. Nikon Coolpix S9050 LCD Screen Replacement, LCD Screen: paso 5, imagen 1 de 1
    • Remove the silver 3.2 mm Phillips #000 screw on the corner of the device to remove the screen.
  6. Nikon Coolpix S9050 LCD Screen Replacement: paso 6, imagen 1 de 2 Nikon Coolpix S9050 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Gently remove pin connector using the spudger to disconnect the screen.
Conclusión
Kyle Gildner
Miembro Desde 11/05/19
199 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G5, Stella Fall 2019 Miembro de IUPUI, Team S1-G5, Stella Fall 2019
IUPUI-STELLA-F19S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 267
