Saltar al contenido principal
Nikon Coolpix S8200 CCD Lens Replacement
Nelson Antiposti
Nelson Antiposti y 6 otros contribuidores
Última actualización: August 12, 2020
10 minuto
Moderado
Introducción
Ir al paso 1
If you have continually received a lens error on your camera and restarting it doesn't help, then you need to replace the CCD lens. This guide walks you through the steps necessary to replace the CCD lens on the Nikon Coolpix S8200.
Qué necesitas
Herramientas
  1. Nikon Coolpix S8200 CCD Lens Replacement, CCD Lens: paso 1, imagen 1 de 1
    • First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
    • Be careful not to remove any extra screws.
  2. Nikon Coolpix S8200 CCD Lens Replacement: paso 2, imagen 1 de 1
    • Once the back is removed, Do Not remove the ribbon cables shown in the within the red circles on the image.
  3. Nikon Coolpix S8200 CCD Lens Replacement: paso 3, imagen 1 de 1
    • Unscrew the two screws around the silver disk-like part indicated by the red circles on the image and then remove them.
    • Next gently remove the black strap indicated by the yellow circle on the image.
    • The black strap can easily snap back on for reassembly.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 27
Todo El Tiempo: 2,343
