Saltar al contenido principal
Nikon Coolpix S7000 Sticky Button Replacement
Shannon Beane
Shannon Beane y 3 otros contribuidores
Última actualización: August 10, 2020
2 - 10 minutos
Fácil
Introducción
Ir al paso 1
When a button gets jammed or becomes sticky it can be very frustrating. It may work sometimes, but requires a lot of pressure. This may be due to a liquid spilling on the device, or it may just be from the button becoming locked out of place. This guide will show you how to reverse the jam quickly so you can resume taking pictures.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: paso 2, imagen 1 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 2, imagen 2 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 2, imagen 3 de 3
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S7000 Sticky Button Replacement: paso 3, imagen 2 de 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S7000 Sticky Button Replacement: paso 4, imagen 3 de 3
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: paso 5, imagen 1 de 1
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: paso 6, imagen 1 de 1
Conclusión
Una persona más ha completado esta guía.
Shannon Beane
Miembro Desde 01/10/17
324 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S2-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 2,473
