Saltar al contenido principal
Nikon Coolpix S7000 Battery Replacement
Jonathan Manigo II
Jonathan Manigo II y 3 otros contribuidores
Última actualización: August 9, 2020
10 segundo
Muy fácil
Introducción
Ir al paso 1
If you noticed that your battery life drains quickly, has power issues, and takes a long time to charge then you may need to replace the batteries. This guide is going to teach someone how to remove and replace the batteries for this specific camera.
Note: Battery component missing for this device.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Nikon Coolpix S7000 Battery Replacement, Battery: paso 1, imagen 1 de 2 Nikon Coolpix S7000 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure that the camera is powered off to prevent damage during battery removal.
    • Locate battery compartment on the bottom of the camera, and slide it to the right.
  2. Nikon Coolpix S7000 Battery Replacement: paso 2, imagen 1 de 1
    • Open compartment, remove old faulty battery by pressing upward on orange tab.
    • Orange battery tab
Conclusión
4 personas más completaron esta guía.
Equipo
USF Tampa, Team S2-G3, Lacy Spring 2017 Miembro de USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Miembros
10 Guías creadas
Un comentario
I replaced the battery correctly and my camera still won’t hold a charge. It will take 2-3 pictures and then shut down. Any suggestions for this?
Julie Carter - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 37
Todo El Tiempo: 2,431
