Saltar al contenido principal
Nikon Coolpix S6300 Zoom Lens Gears
Hung
Hung y 3 otros contribuidores
Última actualización: May 7, 2024
30 minuto
Moderado
Necesita mejores imágenes
Fotos de acción
Pasos faltantes
Introducción
Ir al paso 1
After following the prerequisite guides, the gear can reached by removing the lens apparatus. When the primary gear is exposed, it can simply be lifted out of the camera and inspected.
Qué necesitas
Herramientas
  1. Nikon Coolpix S6300 Zoom Lens Gears, Battery: paso 1, imagen 1 de 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Zoom Lens Gears: paso 2, imagen 1 de 1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Zoom Lens Gears, Buttons: paso 3, imagen 1 de 3 Nikon Coolpix S6300 Zoom Lens Gears, Buttons: paso 3, imagen 2 de 3 Nikon Coolpix S6300 Zoom Lens Gears, Buttons: paso 3, imagen 3 de 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Zoom Lens Gears: paso 4, imagen 1 de 3 Nikon Coolpix S6300 Zoom Lens Gears: paso 4, imagen 2 de 3 Nikon Coolpix S6300 Zoom Lens Gears: paso 4, imagen 3 de 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Zoom Lens Gears: paso 5, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Zoom Lens Gears: paso 6, imagen 1 de 1
    • Disconnect the connectors using a plastic spudger.
    • Be careful when removing the cables to prevent damaging the connectors.
  7. Nikon Coolpix S6300 Zoom Lens Gears: paso 7, imagen 1 de 1
    • You may now remove the internal panel of the buttons.
  8. Nikon Coolpix S6300 Zoom Lens Gears, Display: paso 8, imagen 1 de 1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
  9. Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: paso 9, imagen 1 de 3 Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: paso 9, imagen 2 de 3 Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: paso 9, imagen 3 de 3
    • Remove the four PH00 2.5 mm screws around the edges of the display plate.
    • Remove the three PH00 2 mm screws from the sides of the buttons plate and the 2.5 mm screw from the center of the buttons plate.
    • Lift the buttons plate out of the camera with the plastic tool.
    • Lift the display plate out of the camera with the plastic tool.
  10. Nikon Coolpix S6300 Zoom Lens Gears: paso 10, imagen 1 de 3 Nikon Coolpix S6300 Zoom Lens Gears: paso 10, imagen 2 de 3 Nikon Coolpix S6300 Zoom Lens Gears: paso 10, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use the plastic opening tool to gently flip the white folders at the end of the ribbon cables.
    • Use this tweezers to gently pull the cables out of the holders.
    • Lift the lens apparatus out of the rest of the camera by pushing the front of lens up from the bottom.
  11. Nikon Coolpix S6300 Zoom Lens Gears: paso 11, imagen 1 de 2 Nikon Coolpix S6300 Zoom Lens Gears: paso 11, imagen 2 de 2
    • Use the plastic opening tool to flip the two white clips holding the ribbon cables.
    • Use tweezers to pull the cables from clamps.
    • Use the PH00 screwdriver to remove the three 2 mm screws around the first lens area.
  12. Nikon Coolpix S6300 Zoom Lens Gears: paso 12, imagen 1 de 2 Nikon Coolpix S6300 Zoom Lens Gears: paso 12, imagen 2 de 2
    • Lift the first lens from the rest of the lens apparatus.
    • Use thin tweezers to left and remove the polarizing lens from the apparatus.
  13. Nikon Coolpix S6300 Zoom Lens Gears, Zoom Lens Gears: paso 13, imagen 1 de 1
    • Check to see if there are any items stuck inside the gear.
    • Carefully remove items using tweezers.
    • If the gears are popped out of place, carefully push the gears back into its original position shown in the picture
Conclusión
4 personas más completaron esta guía.
Hung
Miembro Desde 09/01/15
383 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-2, Remmell Fall 2015 Miembro de USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Miembros
10 Guías creadas
Un comentario
Attention rester sur une table, et bien suivre le tutoriel. En effet, il y a des pilles, Pas la batterie: donc si vous touchez le haut de l'appareil, il y a un peux d’électricité max 4w , ce qui surprend....C'est pas dangereux mais cela surprend. Pas toucher le haut de l'appareil..... Ferreria J-C
a420mf - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 1,524
