Saltar al contenido principal
Nikon Coolpix S630 Battery Cover Door Replacement
Aulivia Bounchaleun
Aulivia Bounchaleun y 4 otros contribuidores
Última actualización: January 20, 2025
30 - 40 minutos
Moderado
Fotos de acción
Imágenes Inconsistentes
Bordeador de Pasos
Introducción
Ir al paso 1
Before replacing your battery cover door for your Nikon Coolpix S630 you would need to read how to remove back panel and front panel. Removing both back and front panels are necessary to starting this guide.
Qué necesitas
Herramientas
  1. Nikon Coolpix S630 Battery Cover Door Replacement, Battery Compartment: paso 1, imagen 1 de 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Battery Cover Door Replacement, Battery: paso 2, imagen 1 de 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Battery Cover Door Replacement, Memory Card: paso 3, imagen 1 de 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: paso 4, imagen 1 de 3 Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: paso 4, imagen 2 de 3 Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: paso 4, imagen 3 de 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Battery Cover Door Replacement: paso 5, imagen 1 de 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Battery Cover Door Replacement, Detaching Ribbon: paso 6, imagen 1 de 2 Nikon Coolpix S630 Battery Cover Door Replacement, Detaching Ribbon: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  7. Nikon Coolpix S630 Battery Cover Door Replacement, Front Cover: paso 7, imagen 1 de 1
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  8. Nikon Coolpix S630 Battery Cover Door Replacement: paso 8, imagen 1 de 1
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  9. Nikon Coolpix S630 Battery Cover Door Replacement, Battery Cover Door: paso 9, imagen 1 de 1
    • Locate the battery cover door.
  10. Nikon Coolpix S630 Battery Cover Door Replacement: paso 10, imagen 1 de 2 Nikon Coolpix S630 Battery Cover Door Replacement: paso 10, imagen 2 de 2
    • Press and slide the cover door open.
  11. Nikon Coolpix S630 Battery Cover Door Replacement: paso 11, imagen 1 de 1
    • Locate the small rod that is securing the door in place
    • Using a tweezers, grab the rod and slowly pull the rod out
    • Be careful as you try to pull the rod out because the spring may pop out
  12. Nikon Coolpix S630 Battery Cover Door Replacement: paso 12, imagen 1 de 1
    • Replace battery cover door.
    • To reinstall a new battery cover door, make sure you have these parts: spring, rod, and the battery cover door.
  13. Nikon Coolpix S630 Battery Cover Door Replacement: paso 13, imagen 1 de 1
    • Place battery cover door back into place with spring between the insertion holes.
    • Using a tweezers, gently slide the rod through the insertion holes and through the spring.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 8-56, Johann Spring 2013 Miembro de Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Miembros
18 Guías creadas
Un comentario
I am stuck on step 8. How am I supposed to hold it down and pull the front cover off. I can only get the corner up where the battery goes.
toolshell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 1,714
