Saltar al contenido principal
Nikon Coolpix S5300 LCD Display Screen Replacement
Waleed Chakir
Waleed Chakir y 3 otros contribuidores
Última actualización: August 3, 2020
20 minuto
Moderado
Introducción
Ir al paso 1
The purpose of this guide is to replace the LCD screen. This guide will provide the necessary information to:
  • Disassemble the camera.
  • Replace the screen.
  • Properly reassemble the components involved.
Qué necesitas
Herramientas
  1. Nikon Coolpix S5300 LCD Display Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 2, imagen 1 de 1
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: paso 3, imagen 1 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: paso 3, imagen 2 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement, Outer Casing: paso 3, imagen 3 de 3
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 4, imagen 1 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 4, imagen 2 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 5, imagen 1 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 5, imagen 2 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 5, imagen 3 de 3
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 6, imagen 1 de 2 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 6, imagen 2 de 2
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 7, imagen 1 de 2 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 7, imagen 2 de 2
    • Carefully remove the top button casing by pulling it away from main camera.
  8. Nikon Coolpix S5300 LCD Display Screen Replacement, Button Panel: paso 8, imagen 1 de 1
    • Remove the 2 screws on the silver plate
    • Gently lift the screen and silver plate away from the internal components.
    • Do not separate the plate and screen from the camera
  9. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 9, imagen 1 de 2 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 9, imagen 2 de 2
    • Carefully move the button panel away from the silver plate.
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
    • Safely pull the ribbon cable out and then remove the button panel.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
  10. Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: paso 10, imagen 1 de 2 Nikon Coolpix S5300 LCD Display Screen Replacement, LCD Display Screen: paso 10, imagen 2 de 2
    • Carefully remove the screen away from the silver plate.
    • Carefully fold the screen over exposing the latch for the ribbon cable.
  11. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 11, imagen 1 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 11, imagen 2 de 3 Nikon Coolpix S5300 LCD Display Screen Replacement: paso 11, imagen 3 de 3
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  12. Nikon Coolpix S5300 LCD Display Screen Replacement: paso 12, imagen 1 de 1
    • Once the ribbon cable is disconnected, remove the LCD screen.
Conclusión
Waleed Chakir
Miembro Desde 03/04/16
301 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team 6-1, Bhusal Spring 2016 Miembro de UMass Dartmouth, Team 6-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G1
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 1,248
