Saltar al contenido principal
Nikon Coolpix S4000 Lens Replacement
Matina Newsom
Matina Newsom y otro contribuidor
Última actualización: July 28, 2020
6 minuto
Difícil
Introducción
Ir al paso 1
If the lense on your camera is malfunctioning we suggest first checking out our troubleshooting guide. If you have determined that the lense itself needs replacing please follow this guide to replace it.
Please note that this guide will require the use of a soldering tool to replace the lens completely.
Qué necesitas
Herramientas
Ver más…
  1. Nikon Coolpix S4000 Lens Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Nikon Coolpix S4000 Lens Replacement: paso 2, imagen 1 de 1
    • Push the orange tab back and the battery will pop out.
  3. Nikon Coolpix S4000 Lens Replacement, Casing: paso 3, imagen 1 de 3 Nikon Coolpix S4000 Lens Replacement, Casing: paso 3, imagen 2 de 3 Nikon Coolpix S4000 Lens Replacement, Casing: paso 3, imagen 3 de 3
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Nikon Coolpix S4000 Lens Replacement: paso 4, imagen 1 de 2 Nikon Coolpix S4000 Lens Replacement: paso 4, imagen 2 de 2
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Nikon Coolpix S4000 Lens Replacement: paso 5, imagen 1 de 3 Nikon Coolpix S4000 Lens Replacement: paso 5, imagen 2 de 3 Nikon Coolpix S4000 Lens Replacement: paso 5, imagen 3 de 3
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Nikon Coolpix S4000 Lens Replacement, Lens Casing: paso 6, imagen 1 de 1
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Nikon Coolpix S4000 Lens Replacement: paso 7, imagen 1 de 2 Nikon Coolpix S4000 Lens Replacement: paso 7, imagen 2 de 2
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
  8. Nikon Coolpix S4000 Lens Replacement, Screen: paso 8, imagen 1 de 1
    • Remove the single 2mm Phillips #000 screw.
  9. Nikon Coolpix S4000 Lens Replacement: paso 9, imagen 1 de 3 Nikon Coolpix S4000 Lens Replacement: paso 9, imagen 2 de 3 Nikon Coolpix S4000 Lens Replacement: paso 9, imagen 3 de 3
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
  10. Nikon Coolpix S4000 Lens Replacement: paso 10, imagen 1 de 2 Nikon Coolpix S4000 Lens Replacement: paso 10, imagen 2 de 2
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
  11. Nikon Coolpix S4000 Lens Replacement, Lens: paso 11, imagen 1 de 2 Nikon Coolpix S4000 Lens Replacement, Lens: paso 11, imagen 2 de 2
    • Remove the two 3mm Phillips #000 screws.
  12. Nikon Coolpix S4000 Lens Replacement: paso 12, imagen 1 de 2 Nikon Coolpix S4000 Lens Replacement: paso 12, imagen 2 de 2
    • Turn the camera over and remove a single 4mm Phillips #000 screw.
    • There may be black tape covering the screw.
  13. Nikon Coolpix S4000 Lens Replacement: paso 13, imagen 1 de 2 Nikon Coolpix S4000 Lens Replacement: paso 13, imagen 2 de 2
    • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
  14. Nikon Coolpix S4000 Lens Replacement: paso 14, imagen 1 de 2 Nikon Coolpix S4000 Lens Replacement: paso 14, imagen 2 de 2
    • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
    • The tabs are brittle so use gently force.
  15. Nikon Coolpix S4000 Lens Replacement: paso 15, imagen 1 de 1
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the orange ribbon cable out of the ZIF connector.
    • Separate the lens from the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 32
Todo El Tiempo: 1,306
