Saltar al contenido principal
Nikon Coolpix S3100 Camera Lens Replacement
Jorge
Jorge y 2 otros contribuidores
Última actualización: July 23, 2020
10 minuto
Moderado
Introducción
Ir al paso 1
If you shutter lens does not seem to operate, these guides will help you find the problem.
Qué necesitas
Herramientas
Ver más…
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 1 de 3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 2 de 3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: paso 1, imagen 3 de 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S3100 Camera Lens Replacement: paso 2, imagen 2 de 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: paso 3, imagen 1 de 2 Nikon Coolpix S3100 Camera Lens Replacement: paso 3, imagen 2 de 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: paso 4, imagen 1 de 1
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: paso 5, imagen 1 de 1
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: paso 6, imagen 1 de 1
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: paso 7, imagen 1 de 1
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: paso 8, imagen 1 de 1
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: paso 9, imagen 1 de 1
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: paso 10, imagen 1 de 1
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: paso 11, imagen 1 de 1
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: paso 12, imagen 1 de 1
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: paso 13, imagen 1 de 1
    • The lens is now separated.
Conclusión
11 personas más completaron esta guía.
Jorge
Miembro Desde 03/11/15
1,170 Reputación
7 Guías creadas
Equipo
Colorado Springs, Team 2-4, Panko Spring 2015 Miembro de Colorado Springs, Team 2-4, Panko Spring 2015
UCCS-PANKO-S15S2G4
Miembros de 2
13 Guías creadas
6 comentarios
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - Contestar
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - Contestar
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - Contestar
I have same issue it shutter half opens and doesnt open correctly
shailendra - Contestar
my LCD screen is stuck on white after after i did this :(
andrew welles - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 36
Ultimos 30 días: 95
Todo El Tiempo: 4,738
