Saltar al contenido principal
Nikon Coolpix L840 Buttons Replacement
Abraham Lozano
Abraham Lozano y 4 otros contribuidores
Última actualización: July 4, 2020
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
This guide details the steps required to replace buttons on the back face of the camera. Please use this guide only when a specific button is not working. When the problem involves other parts of the camera or all of the buttons, you may need to replace a component of the circuit board.
Qué necesitas
Herramientas
Ver más…
  1. Nikon Coolpix L840 Buttons Replacement, Motherboard: paso 1, imagen 1 de 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: paso 1, imagen 2 de 3 Nikon Coolpix L840 Buttons Replacement, Motherboard: paso 1, imagen 3 de 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Buttons Replacement: paso 2, imagen 1 de 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Buttons Replacement: paso 3, imagen 1 de 2 Nikon Coolpix L840 Buttons Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Buttons Replacement, Buttons: paso 4, imagen 1 de 1
    • Unscrew the two, right-most, 2 mm screws with a Philips 000.
    • Unscrew the left-most, 4 mm screw with a Philips 000.
  5. Nikon Coolpix L840 Buttons Replacement: paso 5, imagen 1 de 1
    • Slide off the button panel in the marked direction.
  6. Nikon Coolpix L840 Buttons Replacement: paso 6, imagen 1 de 1
    • Flip to the front side of the button panel to access the button sensors.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 1-11, Maness Spring 2016 Miembro de Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Miembros
10 Guías creadas
Un comentario
Where can I get a replacement board for the buttons?
rush - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 2,406
