Nikon Coolpix L820 Device Ports Replacement
Introducción
Ir al paso 1The device ports on a digital camera can be prone to damage that may render them nonfunctional. This guide will lead you through the necessary steps to replace damaged device ports.
Qué necesitas
Herramientas
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
2 personas más completaron esta guía.
Un comentario
Could you explain how the power button is changed? Thank you!!
