Saltar al contenido principal
Nikon Coolpix L340 Battery Replacement
Nikki Butts
Nikki Butts y 2 otros contribuidores
Última actualización: June 29, 2020
5 minuto
Fácil
Introducción
Ir al paso 1
The batteries in your camera only last a certain amount of time before they die and it is time to replace them. Once this happens, the camera will not be able to turn on until all four of the batteries are replaced. The batteries used in this camera are AA batteries.
  1. Nikon Coolpix L340 Battery Replacement, Battery: paso 1, imagen 1 de 2 Nikon Coolpix L340 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L340 Battery Replacement: paso 2, imagen 2 de 2
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: paso 3, imagen 1 de 1
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: paso 4, imagen 1 de 1
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
Conclusión
2 personas más completaron esta guía.
Nikki Butts
Miembro Desde 03/04/16
179 Reputación
1 Guía escrita
Equipo
4 comentarios
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - Contestar
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - Contestar
thestevelink - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 19
Ultimos 30 días: 92
Todo El Tiempo: 10,638
