Saltar al contenido principal
Nikon Coolpix L330 Battery Replacement
Rabiaah A
Rabiaah A y 2 otros contribuidores
Última actualización: June 26, 2020
1 minuto
Muy fácil
Introducción
Ir al paso 1
If your camera does not power on, then most likely you would have to replace your batteries. Follow instruction on this guide to remove your old batteries and replace them.
  1. Nikon Coolpix L330 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure to turn off your camera before replacing the batteries.
    • Turn the camera upside down so you can see the battery chamber.
  2. Nikon Coolpix L330 Battery Replacement: paso 2, imagen 1 de 3 Nikon Coolpix L330 Battery Replacement: paso 2, imagen 2 de 3 Nikon Coolpix L330 Battery Replacement: paso 2, imagen 3 de 3
    • Push the battery chamber lock to the right to open it.
    • Slide the cover down to unhook the battery door.
    • The inner battery housing has orientation stickers to show the way in which the batteries should be placed.
  3. Nikon Coolpix L330 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the old batteries from the battery chamber.
    • Replace the batteries with new ones.
Conclusión
Una persona más ha completado esta guía.
Rabiaah A
Miembro Desde 02/09/16
128 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 2-10, Cagle Spring 2016 Miembro de USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 24
Ultimos 30 días: 53
Todo El Tiempo: 6,245
