Saltar al contenido principal
Nikon Coolpix L18 Front Cover Replacement
Andrea Govea
Andrea Govea y 6 otros contribuidores
Última actualización: June 23, 2020
5 minuto
Fácil
Introducción
Ir al paso 1
In order to reach the internal elements of the camera (lens, flashbulb, etc.), the following steps will tell you how to remove the front cover.
Qué necesitas
Herramientas
  1. Nikon Coolpix L18 Front Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Front Cover Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L18 Front Cover Replacement: paso 2, imagen 2 de 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Front Cover Replacement: paso 3, imagen 1 de 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Front Cover Replacement, LCD Screen: paso 4, imagen 1 de 1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Front Cover Replacement: paso 5, imagen 1 de 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Front Cover Replacement: paso 6, imagen 1 de 1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Front Cover Replacement, Front Cover: paso 7, imagen 1 de 1
    • Pry back the front cover of the camera starting from the right side.
Conclusión
Una persona más ha completado esta guía.
Andrea Govea
Miembro Desde 10/11/10
365 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-23, Regan Fall 2010 Miembro de Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 3,343
