Saltar al contenido principal
Nikon Coolpix 775 Motherboard Replacement
Suketu Patel
Suketu Patel y 3 otros contribuidores
Última actualización: May 7, 2024
15 - 50 minutos
Moderado
Introducción
Ir al paso 1
Do you think your motherboard is fried? This guide can help you walk through the removal of this motherboard for the Nikon Coolpix 775.
Qué necesitas
Herramientas
Ver más…
  1. Nikon Coolpix 775 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the camera, so the bottom is facing up.
  2. Nikon Coolpix 775 Motherboard Replacement: paso 2, imagen 1 de 2 Nikon Coolpix 775 Motherboard Replacement: paso 2, imagen 2 de 2
    • Slide the gray latch to the open "pac-man" symbol.
  3. Nikon Coolpix 775 Motherboard Replacement: paso 3, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 3, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 3, imagen 3 de 3
    • Flip up the cover and remove the battery inside the slot.
  4. Nikon Coolpix 775 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Unscrew the eight 4mm long JIS #00 screws from the bottom, right side, and the left side.
  5. Nikon Coolpix 775 Motherboard Replacement: paso 5, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 5, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 5, imagen 3 de 3
    • Grab the camera with both your hand from the front and the back.
    • Pull the two parts apart.
    • You may have to pull at different angles to get the two parts to separate, but make sure you don't pull too hard because there is a wire connection on the inside.
  6. Nikon Coolpix 775 Motherboard Replacement: paso 6, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 6, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Flip the camera back so you can see the top.
    • Pull the ribbon cable out of the socket connecting to the motherboard by using your hands or tweezers.
    • Be careful not to puncture or rip the ribbon cable.
  7. Nikon Coolpix 775 Motherboard Replacement: paso 7, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 7, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 7, imagen 3 de 3
    • Look back to the top of the camera.
    • Flip up the tab that is exposed right by the dial using tweezers.
    • Release the ribbon to be able to separate the top part of the back of the camera.
    • Be careful not to rip the ribbon cable.
  8. Nikon Coolpix 775 Motherboard Replacement: paso 8, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 8, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 8, imagen 3 de 3
    • Look at the top side of the camera.
    • Unscrew the two 4mm Phillips #00 screws.
    • Unscrew the 2mm JIS #00 screw as well.
  9. Nikon Coolpix 775 Motherboard Replacement: paso 9, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 9, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 9, imagen 3 de 3
    • Push or slide the the top dial toward the backside of the camera to unclip from the motherboard.
  10. Nikon Coolpix 775 Motherboard Replacement: paso 10, imagen 1 de 2 Nikon Coolpix 775 Motherboard Replacement: paso 10, imagen 2 de 2
    • Pull the red and black wire out of the socket on the motherboard.
    • Pull motherboard up out of camera.
  11. Nikon Coolpix 775 Motherboard Replacement: paso 11, imagen 1 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 11, imagen 2 de 3 Nikon Coolpix 775 Motherboard Replacement: paso 11, imagen 3 de 3
    • Pull the ribbon connected to the dial off the motherboard.
Conclusión
Suketu Patel
Miembro Desde 11/05/18
303 Reputación
2 Guías creadas
Equipo
IUPUI, Team S2-G3, Baechle Fall 2018 Miembro de IUPUI, Team S2-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G3
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 306
