Nikon COOLPIX P7700 Back Casing Replacement
Introducción
Ir al paso 1This guide showcases how to replace the back casing on a Nikon COOLPX p7700 camera. By following these seven simple steps, you should comfortably be able to remove the casing on the camera to get to the inside.
Qué necesitas
Herramientas
Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
Remove the side panel.
2 personas más completaron esta guía.
