Saltar al contenido principal
Nikon COOLPIX P7700 Back Casing Replacement
Dustin Wahl
Dustin Wahl y 4 otros contribuidores
Última actualización: July 10, 2024
15 - 20 minutos
Moderado
Introducción
Ir al paso 1
This guide showcases how to replace the back casing on a Nikon COOLPX p7700 camera. By following these seven simple steps, you should comfortably be able to remove the casing on the camera to get to the inside.
Qué necesitas
Herramientas
  1. Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: paso 1, imagen 1 de 2 Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: paso 1, imagen 2 de 2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Back Casing Replacement: paso 2, imagen 1 de 1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Back Casing Replacement: paso 3, imagen 1 de 1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Back Casing Replacement: paso 4, imagen 1 de 1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Back Casing Replacement: paso 5, imagen 1 de 1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Back Casing Replacement: paso 6, imagen 1 de 2 Nikon COOLPIX P7700 Back Casing Replacement: paso 6, imagen 2 de 2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Back Casing Replacement: paso 7, imagen 1 de 1
    • Remove the back casing.
Conclusión
2 personas más completaron esta guía.
Dustin Wahl
Miembro Desde 03/11/15
784 Reputación
4 Guías creadas
Equipo
Colorado Springs, Team 2-7, Panko Spring 2015 Miembro de Colorado Springs, Team 2-7, Panko Spring 2015
UCCS-PANKO-S15S2G7
Miembros de 3
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 1,959
