Saltar al contenido principal
Nike SportWatch GPS Battery Replacement
Ian Eichorn
Ian Eichorn y 6 otros contribuidores
Última actualización: July 27, 2021
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
If your battery is dying, you may have to replace it. Follow this guide to take the watch apart and replace the battery.
Qué necesitas
Herramientas
Ver más…
  1. Nike SportWatch GPS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Battery Replacement: paso 2, imagen 1 de 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Battery Replacement: paso 3, imagen 1 de 1
    • Pry the black plastic piece above the battery out using a nylon or metal spudger.
    • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
  4. Nike SportWatch GPS Battery Replacement: paso 4, imagen 1 de 1
    • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
  5. Nike SportWatch GPS Battery Replacement: paso 5, imagen 1 de 1
    • The battery should then easily come out of the watch.
Conclusión
To reassemble your device, follow these instructions in reverse order. Once reassembled, plug the watch back into a USB computer port to turn the watch back on and start the initial charge. Let charge to full capacity.
9 personas más completaron esta guía.
Ian Eichorn
Miembro Desde 10/22/15
678 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
Miembros de 3
5 Guías creadas
8 comentarios
Nice tutorial!
Do you know where I can buy the battery from?
Steeve H - Contestar
Where can i buy a replacement battery?
Ricardo Henriques - Contestar
Thank you for this guide and the link to the replacement battery.
The battery I received had an extra circuit board and the contacts/metal bands were thinner and further apart thus making direct replacement difficult, there was no way to create proper connection with the spring contacts using the black plastic pc . I ended up removing the extra PCB and soldered the battery with short leads directly to the spring contacts and this worked well.
Unfortunately, it seems the battery wasn't the only issue with the watch.. last night it was fully charged however by this morning it was almost totally empty.
amveszter - Contestar
I bought mine from batteryspace.com. Great place for all battery types.
peezo83 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 28
Todo El Tiempo: 17,264
