Saltar al contenido principal
NABI XD Motherboard Replacement
Marissa Schiereck
Marissa Schiereck y 5 otros contribuidores
Última actualización: May 7, 2024
4 minuto
Moderado
Introducción
Ir al paso 1
This guide should be used when replacing the motherboard or other components. Has the NABI XD taken water damaged or won't turn on after troubleshooting the charger. Then, replacing the motherboard will fix you device.
Qué necesitas
Herramientas
Ver más…
  1. NABI XD Motherboard Replacement, Rear panel: paso 1, imagen 1 de 2 NABI XD Motherboard Replacement, Rear panel: paso 1, imagen 2 de 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Motherboard Replacement: paso 2, imagen 1 de 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Motherboard Replacement, Battery: paso 3, imagen 1 de 2 NABI XD Motherboard Replacement, Battery: paso 3, imagen 2 de 2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Motherboard Replacement: paso 4, imagen 1 de 1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Motherboard Replacement, Charging port: paso 5, imagen 1 de 2 NABI XD Motherboard Replacement, Charging port: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Motherboard Replacement: paso 6, imagen 1 de 1
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  7. NABI XD Motherboard Replacement, Motherboard: paso 7, imagen 1 de 3 NABI XD Motherboard Replacement, Motherboard: paso 7, imagen 2 de 3 NABI XD Motherboard Replacement, Motherboard: paso 7, imagen 3 de 3
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  8. NABI XD Motherboard Replacement: paso 8, imagen 1 de 3 NABI XD Motherboard Replacement: paso 8, imagen 2 de 3 NABI XD Motherboard Replacement: paso 8, imagen 3 de 3
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  9. NABI XD Motherboard Replacement: paso 9, imagen 1 de 2 NABI XD Motherboard Replacement: paso 9, imagen 2 de 2
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  10. NABI XD Motherboard Replacement: paso 10, imagen 1 de 2 NABI XD Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  11. NABI XD Motherboard Replacement: paso 11, imagen 1 de 1
    • Lift the motherboard up away from the Nabi XD.
Conclusión
Equipo
USF Tampa, Team 17-2, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
Miembros de 3
12 Guías creadas
Un comentario
Donde puedo conprar la pelicula de la tables o el displey y tatil
maria-201309 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 265
