NABI XD Charging port Replacement
Introducción
Ir al paso 1Is your charging port damaged, can't charge your device no matter what you have tried. Replacing the charging port may fix those problems.
Qué necesitas
Herramientas
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Herramienta utilizada en este paso:Tweezers$4.99
Remove the two 4mm Phillips screws with the PH#0 screwdriver.
Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
