Saltar al contenido principal
Mpow 059 Battery  Replacement
Danielle Furtado
Danielle Furtado y 3 otros contribuidores
Última actualización: September 21, 2022
15 - 30 minutos
Difícil
Fotos de acción
Necesita más imágenes
Introducción
Ir al paso 1
Find out how to change the battery in your Mpow 059 Headphones. The battery is located in the left ear cup and is simple to replace. This repair may be necessary if your batteries are no longer working and it may affect the noise cancellation, signal transmission, and audio drivers.
Note: If possible, make sure your battery is completely depleted before replacing it. If a lithium-ion battery is punctured during replacement, it may spark and create a fire.
Qué necesitas
Herramientas
Ver más…
  1. Mpow 059 Battery  Replacement, Ear Cushion: paso 1, imagen 1 de 2 Mpow 059 Battery  Replacement, Ear Cushion: paso 1, imagen 2 de 2
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
  2. Mpow 059 Battery  Replacement: paso 2, imagen 1 de 1
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
  3. Mpow 059 Battery  Replacement, Battery: paso 3, imagen 1 de 2 Mpow 059 Battery  Replacement, Battery: paso 3, imagen 2 de 2
    • Use the Phillips #1 screwdriver to remove the six screws holding the red plastic cover in place.
    • Carefully peel the plastic cover off the left cup to reveal the ear cup's internal components.
    • There is some adhesive holding the red cover down so be careful as you remove it so it doesn't break or crack.
  4. Mpow 059 Battery  Replacement: paso 4, imagen 1 de 1
    • Use the JIS J00 screwdriver to remove the 3 screws that secure the black cover.
  5. Mpow 059 Battery  Replacement: paso 5, imagen 1 de 1
    • Remove the black cover to reveal the battery. The battery is attached to the back of the black cover.
    • The plastic cover of the headphones is connected to the battery housing by a wire connector. Be careful not to harm this cable by pulling the cap too hard during disassembly.
    • Undo the cable and remove the battery.
Conclusión
7 personas más completaron esta guía.
Equipo
8 comentarios
Hello
What kind of glue should I use to put new pad?
Martin Dromigny - Contestar
What is the part number for the replacement battery? Where can I find one?
hdm_1@comcast.net - Contestar
Battery is a 503030 3.7v 420mAh
Mark Jobe - Contestar
First, you need to pry the piece behind the R headphone, which is itself adhered. THEN you need to pry the battery off of the backing.
And finally, you can realize you did all of this for nothing if you don't know how to solder. The battery cables are soldered onto the chip, making it impossible to replace without soldering in the replacement wires.
biggles1701 bob - Contestar
This is good to know. I was thinking there was something missing as to how the battery is connected. While I'd like to save my headphones from the landfill, it looks like a case of planned obsolescence. Guess I'll be hunting for new headphones with better repair-ability
Nell -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 22
Ultimos 30 días: 76
Todo El Tiempo: 6,757
