Motorola V2397 Motherboard/Screen Replacement
Qué necesitas
Press and hold the button on the battery cover
Pull the battery cover down and out to remove it
Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
Place your plastic opening tool in between the motherboard and the front cover of the phone
Apply a small force to lift the motherboard away from the front cover
Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
Carefully separate the screen from the motherboard
